Why CV to Midi ?
Pitch to Midi works well with a Sonuus 12m Midiport ...
Been using this for 3 years .... and even persuaded Sonuus to do some scale programming !
https://www.youtube.com/watch?v=A6T8qQ2yAbM
Now anyone got a hint as to getting Midi note-on/off out of a Theremini ?
How to convert CV to MIDI?
Re: How to convert CV to MIDI?
Tim Blake - Crystal Machine
' Lighting the Lasers in Your Hearts for 43 Years "
Tim,
At what point exactly do you want your Theremini to output a Note-on or Note-off message? That is the trickiest point to define, as the typical use is to fade notes in or out with the amplitude antennae. Perhaps a trigger could be generated at an exact distance from the antennae? You'd also need a switch on the Theremini to activate/deactivate the Note-on/off function.
It seems like you've put some serious thought into this already. Curious as to how you'd see it implemented.
Stephen
Stephen
