Etherwave Pro 220V What is the Power (
Hello, I've got an urgent technical question. I hope there's someone to help over this festive season. I've travelled from the UK to Japan for a gig, and I've taken my Etherwave Pro and 220V power supply with me. I now need to buy a voltage transformer. My question: What is the power (W) of the unit? I need to know this in order to choose the correct transformer. I'd really appreciate a quick reply. Arigato.
standard etherwave
it`s the standard Etherwave rather than the Etherwave Pro.
Re: Etherwave Pro 220V What is the Powerz
Going by your follow-up post and assuming you have the standard Etherwave, the kit I just built, the power supply that came with it specifies an output of 14VDC at 200 mA, which I believe gives a wattage of 2.8 watts. The manual also specifies that the theremin would draw 30 milliamperes on a battery supply of +/- 18V, which yields a wattage of 540 milliwatts. I think.. I'm just a musician, not a licensed electronic engineer. Somebody correct me if my calculations are wrong.regmtait wrote:Hello, I've got an urgent technical question. I hope there's someone to help over this festive season. I've travelled from the UK to Japan for a gig, and I've?taken my Etherwave Pro and 220V power supply with me. I now need to buy a voltage transformer. My question: What is the power (W) of the unit? I need to know this in order to choose the correct transformer. I'd really appreciate a quick reply. Arigato.
Hope that helps a bit..
Barry
