MuRF Stereo question
Vsyevolod
Re:
Post by Vsyevolod » Wed Sep 25, 2013 4:38 pm
Prime NL wrote:Also keep in mind to use TS cables for the audio signals.
Is this really true? I'm using TRS cables for connecting my Foogers together. No apparent problems on this end, I'm assuming that they just use the TS portion of the cable and ignore the Ring.
Stephen
bozobreak
Re: MuRF Stereo question
Post by bozobreak » Thu Oct 03, 2013 11:32 am
Just wanted to chime in and tell that I've done this small mod (input to left/right).
Works great, now I have the input signal on both Left and Right channel even when the MF-105M is off.
HaloHalo0407
Post by HaloHalo0407 » Wed Apr 27, 2016 10:45 am
Hi folks,
sorry to dig this thread out.
I would like to know how to set my Midi MuRF to stereo out when bypassed.
Had open the back and this circuit thing do really confused me.
I couldn't identify the jumper to flip. Not sure whether the Midi murf could do the same adjustment.
Suggestion needed! Thanks :D
_DemonDan_
Post by _DemonDan_ » Wed Apr 27, 2016 12:32 pm
Just follow the magic footprints...
HaloHalo0407
Post by HaloHalo0407 » Wed Apr 27, 2016 1:46 pm
_DemonDan_ wrote:Just follow the magic footprints...
Wow! Thanks for your reply, though it looks super tech difficult :shock:
I guess I should bring my murf to tech worth trust to see if he can solve this soldering thing for me.
Thx :D
HaloHalo0407
Re:
Post by HaloHalo0407 » Wed Apr 27, 2016 2:01 pm
And thanks for the pic labeling out the exact place to solder.
Now this quote make sense to me lol.
Amos wrote:The short answer as to whether it would be OK to solder a switch to the Midi Murf to enable mono/stereo bypass mode-switching is... I haven't tried it, so I don't know. But it sounds like it would be OK.
Yes the pads are labeled: "IN to L&R" above the pads, and "JMP3" written vertically to the left of the pads. Location is upper middle of the circuit board as you look into the underside of the pedal with bottom plate removed.
DonutDude
Post by DonutDude » Wed Apr 27, 2016 5:42 pm
I just keep my Midi Murf engaged (green light on) and turn the mix knob down to zero when I don't want to hear the effect. I still get sound out of both outputs that way and when I want to hear the Murf effect I just turn up the mix. Not sure that is what you are looking for but thought I'd mention it before you start soldering an expensive Moogerfooger board. :)
_DemonDan_
Post by _DemonDan_ » Wed Apr 27, 2016 5:51 pm
DonutDude wrote:Not sure that is what you are looking for but thought I'd mention it before you start soldering an expensive Moogerfooger board.
It's actually very easy to do. Just get a small blob of solder on that bisected pad and it's done.
Vsyevolod
Post by Vsyevolod » Wed Apr 27, 2016 11:47 pm
I'm with Donut...
In fact I do the 'Mix full left' instead of bypass much of the time.
Stephen
fuzulu
Post by fuzulu » Sun May 15, 2016 8:05 pm
Yeah mix full left is the best, I aint opening it and plus when u switch on the pedal it wont be on bypass... so it saves me a step...
