Introducing the MF-105M MIDI MuRF
- Portamental
I downloaded the MIDIMurf software.
My only WinXP computer is an Acer Netbook.
The problem is the interface is chopped off below the peak LEDs due to the limited resolution of the netbook. If there are any controls down there, I can't get to them.
I'm going to peek in the PDF, hoping to find hotkeys to get there or to scale the interface (which is cool BTW)
I have the Mac version but I suspect the PC version is the same in that there is an "advanced" option for LFO Rate and ENV scale (knobs) plus fake switches for Staccato off/on and Triplets off/on.MC wrote:I downloaded the MIDIMurf software.
The Mac version is fixed meaning that it won't scale to screen resolution. I think this is due to the fancy picture that they took and photoshopped to look exactly like the MurF. It's quite nice.
Hope you get it adjusted soon, it's a great piece of software especially for building your own patterns (the rest of it is just novel as far as modifying parameters).
-Mike W. from NJ
[/img]
- Portamental
I know exactly what you mean. Not satisfied, with a standard size Sony Vaio, I selected a high-end netbook, because of the outstanding performance of it's audio card. The lower resolution was a problem in the beginning, but since I write almost all the music software I use, I reworked my recording software to fit the display.MC wrote:I downloaded the MIDIMurf software.
At this time, the Midi-Murf pattern editor is the only piece of software I would like to use on the netbook but they are not a good match. I think (from memory) that there is a way to move the main screen panel just what it takes for all of the controls to be accessible with the mouse or keyboard, but it's not very convenient.
1024 x 600 resolution is a lot less resolution than a typical notebook, but the small size, weight, and long battery life are making Netbooks a truly portable solution, at last. There's a lot of Netbooks in my future: I selected them as the base of a work project.
I would love a redesigned Midi-Murf pattern editor that would fit in 600 vertical pixels (minus the task bar).
