MF103 - biphase and then some?!
So I just discovered the Sweep In jack on the phaser. I was always kinda baffled why there where 2 cv ins for one knob. But after reading the manual a couple time it finnaly clicked! In 12stage mode the 103's lfo controls 6 of the stages and the lfo being fed into the sweep in controls the other 6 stages creating to independant phasers! Using the ring mods carrier out to the sweep in produces some amazing results. (Warblely sine wave rising up into fm). Has anyone else messed with this much, I don't recall it being mentioned before. I LOVE MOOG
I've played around a bit with similar setups running the ring mod and phaser through the LP's Audio In with amazing results, making fine changes with my potentiometer bank. Unfortunately, I can't run stereo with my current setup without running stuff through my Aiwa alarm clock/30 watt stereo.
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, 1983 Hammond organ.
ColorForm, actually it's a 15 watt per channel bookshelf stereo run through two 12" endtable speakers from 1963. I just use it as an alarm clock.
I don't have an MF-107, but yes, r05c03 I believe that's the idea.
Don't quote me on that, though I'm 99% sure that's how it works.
- soundxplorer
The MF-103 rocks. Just the other day I picked up an Electro-Harmonix Small Stone to do a side-by-side comparison (knowing I could return the EH). I figured if it sounded as good as the 103, I could sell the Fooger and get off cheap with the Small Stone.
I made my decision in under a minute: keep the 103.
The EH did sound great, but added a "haze" to the original sound, or made it a little "blurry"-sounding. The 103 is much clearer-sounding to me. When I say "clearer", I don't mean it lacks richness or depth. I mean it preserves all of the nuances of the original signal.
All of my testing was done with a Moog LP, not a guitar. I can see how a guitarist might prefer the color that the EH gives your tone. The other thing that bugged me about the EH was it has no wet/dry mix control.
