My Bass MuRF only seems to play (or detect) stereo configuration when plugged into the L/Mono jack. Only half of the filters work and when I plug the same single cable into the Right output the other half of the filters work and not the others. I understand that when running in stereo the filters are divided but I’m only trying to run the MuRF in mono but I can not get all the filters to properly work. Is there a problem with the pedal and is there any kind of solution to this?
