Moog Music Forum
Share Ideas and Pass the word
CP-251 bottom power supply?
Postby leemccarthyn » Fri Jan 18, 2019 1:28 pm
Hi
Have a couple of old CP-251 with the red jacks. They have power supply inputs on the topside and bottom. Just got one off e-bay which is the new model without the red rings. Does not have a power supply on the bottom, and has a plastic plug in the back panel where the supply jack should be. Was this changed with the newer models, or was this somehow modified by a previous owner? If it was changed, is there a way to get the part for the power supply to be in the back? Probably will rack this like the other units and I use the back supplies for them in the rack.
leemccarthyn
Re: CP-251 bottom power supply?
Postby electronicpoison » Sun Jan 20, 2019 11:03 pm
hello it is normal that you have two ways one for the rack and the other when you put the 251 on a table.
electronicpoison
Postby electronicpoison » Sun Jan 20, 2019 11:06 pm
sorry take the black plastic away and you got it ,i hope
electronicpoison
Return to Moogerfooger Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
