Y cable to split CV?
ClintAu
Post by ClintAu » Sun Jul 08, 2018 1:44 pm
I was wondering whether it's OK to use a Y-cable such as...
https://www.thomann.de/gb/pro_snake_tpy_2009_jpp.htm
...to split a CV signal with the Moogerfoogers? Eg, to split an LFO from the CP-251 out to two Moogerfooger inputs. I know it's preferable to use the CP-251 mult section, but I don't want to tie it up for this case. I suppose there's a problem using it with an expression pedal because they expect power, but I wouldn't be doing that.
In Eurorack-land they have stackable 3.5mm cables which neatly solve this problem. Is there something equivalent for 6.3mm jack connectors?
Moogerfoogers, Minitaur, Win10. Previously: Slim Phatty, Voyager
Acid Mitch
Re: Y cable to split CV?
Post by Acid Mitch » Tue Jul 10, 2018 4:05 am
That cable does not split anything. It’s a stereo jack to two mono jacks.
You want a mono jack that gets split to two mono jacks.
ClintAu
Post by ClintAu » Wed Jul 11, 2018 4:33 am
Thanks! I haven't found an elegant solution for that. I suppose this should work then:
https://www.amazon.co.uk/6-35mm-Mono-2- ... B005JKY43K
Acid Mitch
Post by Acid Mitch » Sat Jul 14, 2018 4:18 am
Aye, that’ll work.
The only downside I found with adapters like that is that the cables end up sticking out quite far and with the extra weight you have to be careful not to knock them.
ClintAu
Post by ClintAu » Thu Jul 19, 2018 1:25 pm
Agreed, rather inelegant :)
