I currently own an M104 delay (as well as a Minifooger tremolo) and am seriously considering purchasing the 105 Murf. I am a guitarist and currently do not run midi from the stage. Is there a way to sync up these pedals by using the tap tempo function on the 104?
Thank you
M104 and M105 tempo sync?
Re: M104 and M105 tempo sync?
Hi, welcome to the forum.
The answer is no. You can sync them using a MIDI source though and that could be any number of things.
There are possible solutions from disaster area, and you will likely need a splitter like a MIDi solutions Quadra thru.
