I recently bought a mf-delay but I think I'm having some issues with the feedback control. In the instructions it says that past 2 o'clock the feedback enters infinite mode, but I think this is not happening with mine. Even if I have the feedback control set at the maximum value, after one second I don't get any sound at all. I was expecting that the mf-delay when the feedback is full would output a continuous repeated sound with no decay even when the input stops. Isn't it?
I tried both with a battery and a power supply and the results where always the same.
Minifooger delay feedback problem
- stiiiiiiive
Re: Minifooger delay feedback problem
Seems to be a problem. You should contact Moog tech support via their website.
Did you get to the bottom of this? I am having the exact same issue.
Cheers
Cheers
- WarnerWilson
Delayed feedback and signal delays should be about the same. Maybe a node has poor contact. Can it be tested?
Jotrin is a global supplier of electronic components, whether it is difficult to find or popular electronic components, you can find it at Jotrin.
