Cluster Flux question
kosis
Post by kosis » Sat Jan 25, 2014 5:56 am
I'm considering getting a Cluster Flux, mainly for the stereoization and reverb it offers. Can the controls be adjusted so that it gives you the reverb without having any chorus/flange effect?
stiiiiiiive
Re: Cluster Flux question
Post by stiiiiiiive » Sat Jan 25, 2014 7:57 am
Hi Kosis, and welcome to the forum :)
The ClusterFlux doesn't offer reverb. It's hard, I know ;)
Fantastca
Post by Fantastca » Sat Jan 25, 2014 12:42 pm
But the stereoization you can make with it is delicious.
Moog Sub Phatty (firmware 2.1.12 beta, editor 1.1.0) | Ableton Live 9.7 | macOS Sierra 10.12.3
Rabalder
Post by Rabalder » Sat Jan 25, 2014 9:23 pm
+1 for stereoization
kosis
Post by kosis » Sun Jan 26, 2014 4:45 am
I read a couple reviews which mentioned a light plate reverb could be dialed in somehow.
unfiltered37
Post by unfiltered37 » Sun Jan 26, 2014 11:34 am
I don't have a CF, but I have a 104 delay, and yes, you can get reverby sounds with high speed delays and long feedback. I use it all time because I don't like digital reverb. I'll throw it on an aux bus for drum kit, or feed it to a speaker with room mics to create a chamber type effect. Anyway you do it, the BBD's are going to sound great with almost anything.
stiiiiiiive
Post by stiiiiiiive » Sun Jan 26, 2014 12:57 pm
Oh I did not get that, sorry.
Indeed, fast delay and high feedback lead to a kind of reverb, more roomy than platey I would say.
But then the feedback setting needed for you chorus or flanger would only be reachable if you break the setting for the reverb. I mean this is not a multieffect but rather a quite parametrable device capable of several types of effects.
Vsyevolod
Post by Vsyevolod » Sun Jan 26, 2014 7:10 pm
I never thought of the ClusterFlux as a reverb type unit. So I tried it out just now and yes, when set to 'chorus', setting the delay somewhere between 6 and 10, mix at 12:00, and a light amount of feedback, you will get anywhere from 'slapback' echo, to a mushy, smeared sound depending on your settings.
And yes, if you're using it in this way, you cannot get other types of chorus or flange at the same time.
Stephen
kosis
Post by kosis » Sun Jan 26, 2014 10:59 pm
Thanks for info. I'm getting one.
