vocals through midimurf?
Rabalder
Post by Rabalder » Sat Nov 30, 2013 9:19 pm
I cant find any videos or samples on the web where someone is singing/speaking through a midimurf..
Have you seen any?
Ledbetter
Re: vocals through midimurf?
Post by Ledbetter » Sun Dec 01, 2013 12:50 am
I think it would render the words unintelligible, but maybe not. Give it a try and post the result?
unfiltered37
Post by unfiltered37 » Sun Dec 01, 2013 2:21 am
No way, not unless you had super intense and fast modulation. That would be cool though. Just playing the filters is would be like running it through a graphic eq with high resonance. Probably.
Vsyevolod
Post by Vsyevolod » Wed Dec 04, 2013 4:40 pm
One approach to using a Murf with vocals would be to use Pattern 1, which is essentially no pattern. This allows you to have the Murf act as a graphic EQ. You can still use the LFO to modulate the center frequencies which is a subtle effect best heard on Pattern 1. If one decides to use one of the other Patterns, setting the envelope at 12:00 will give a more subtle result than 3:00 or 9:00. Also, even the most extreme settings can be used with vocals as long as the Mix knob is set tastefully.
Stephen
Rabalder
Post by Rabalder » Sun Dec 08, 2013 8:36 pm
Ledbetter wrote:Give it a try and post the result?
I dont have one, thats why I ask...
Cant find any demoes or audio samples or anything on the subject.
Im getting either a murf or an oto biscuit.
Sir Nose
Post by Sir Nose » Wed Dec 11, 2013 9:15 am
They are similar in that they are both sequenced filter effects. So, you can pull off some similar things. But ...
they both add tons of color. An each unit's color is very distinctive.
Murf: croaky, robotic, throaty/whispy, punchy
Biscuit: crunchy, buttery, bleeepy, grimey-dirty-filth
