MF-104M VST Controller
muksys
Post by muksys » Sat Sep 08, 2012 11:21 pm
Hey all!
So many awesome things under the hood! Put together a panel in CTRLR if anyone is interested. Can be found here
Voltor07
Re: MF-104M VST Controller
Post by Voltor07 » Sun Sep 09, 2012 11:32 pm
:shock: Wow, that looks awesome!
Sub 37 #000068, Minitaur, CP-251, MF-102&103, EHX #1 Echo, EHX Space Drums/Crash Pads, QSC GX-3, Miracle Pianos, Walking Stick ribbon controller, Synthutron.com, 1983 Hammond organ.
BHC303
Post by BHC303 » Mon Sep 10, 2012 5:37 am
Sweet, cheers mate :D
Cant wait to have a look at this :mrgreen:
BHC303
Post by BHC303 » Mon Sep 10, 2012 5:45 am
Sorry... how do I get this to work on mac?
muksys
Post by muksys » Mon Sep 10, 2012 5:09 pm
@ BHC303, download this and install. It can be used either as standalone or as a VST in your DAW. If you are having issues, check the forum here
BHC303
Post by BHC303 » Tue Sep 11, 2012 5:41 am
Cheers mate, tried last night with no luck but worked a treat toady, now for the fun part :)
Thanks again
:mrgreen:
BHC303
Feel free to make one for clusterflux too :mrgreen: :mrgreen: :mrgreen: lol
BHC303
Post by BHC303 » Wed Sep 19, 2012 6:41 am
Still trying to figure out how to open this in ableton... I will jump on forum tomorrow. (for some reason ableton cant see it) I can search for it and ableton finds an AU unit of Ctrl i(plug search feature of live) I can open this... but cant link it up to the 104m...
I have noticed one small bug though, if you select filter type (bright) to change to dark you cant revert to back bright.
Cheers
peter ripa
Post by peter ripa » Thu Sep 20, 2012 1:58 pm
it works with cubase?
where do i put the file?
/thx
www.peterripa.com
http://www.peterripa.com/cgi-bin/index.cgi?action=musik
muksys
Post by muksys » Thu Sep 20, 2012 9:51 pm
BHC303 wrote:Still trying to figure out how to open this in ableton... I will jump on forum tomorrow. (for some reason ableton cant see it) I can search for it and ableton finds an AU unit of Ctrl i(plug search feature of live) I can open this... but cant link it up to the 104m...
Cheers
Interesting. I don't use Ableton, so I cannot test. It could be a ctrlr version compatibility problem. The filter select works fine for me in stand-alone mode. I'll load it into Cubase and see how that goes on my end. FWIW, building those panels are pretty easy. It took me a night to figure out how everything works and I'm all thumbs when it comes to MIDI or computer programming.
muksys
Post by muksys » Thu Sep 20, 2012 10:00 pm
peter ripa wrote:it works with cubase?
/thx
So, I just popped open Cubase and it works fine. When you install ctrlr, be sure the VST goes into your VST folder you use for Cubase. In cubase go to Devices > VST Instruments. From there left click one of the bars that says "No Instruments". When the drop down menu appears, select the ctrlr VST. When it opens, click on "Devices". Be sure to set up the correct MIDI OUT thats going to the MF-104M. Then click on Open and navigate to where you have this panel saved.
peter ripa
Post by peter ripa » Thu Nov 01, 2012 2:51 pm
right i installed the vst CTRL opened the panel within it and set the right mididevice. when i turn the knobs on the ctrl interface my 104m doesnt respond. is it supposed to respond all the time or do i have to send the snapshot someway. i tried all midi channels without luck. do you have any ideas?
thx/peter
www.peterripa.com
alexone
Post by alexone » Mon Jan 07, 2013 6:57 pm
Hello,
The link does not work. Where can we find this controller?
Alex
herbiewonder
Post by herbiewonder » Thu Aug 01, 2013 11:56 am
Hi. I'm also looking for the VST. Does anyone out there have it who is willing to share? I'm actually pretty surprised that Moog doesn't have one created. Thanks.
trapezius
Post by trapezius » Sun Oct 12, 2014 8:01 am
Bump! Anyone have this? It would be a lifesaver.
