MF-102 tremolo vs MF-108M tremolo
Posted: Sat Mar 17, 2012 1:00 am
by David Bulog
To my ears the Moog MF-102 tremolo effect is better and can handle more signal input then the MF-108M tremolo settings
Anyone prefer the 108 tremolo sound?
is there any way I can sync the MF-102 by sending it a gate input from a drum machine
thanks in advance
Re: MF-102 tremolo vs MF-108M tremolo
Posted: Sat Mar 17, 2012 4:40 am
by jeepo
The easiest way to sync the mf102 to a drum machine would be to use a mp201. The cheapest way would be to output a fitting sound to an envelope follower then plug the output into the carrier. If it is a cv sequencer more options may work.
Posted: Sun Mar 18, 2012 11:18 pm
by ChrisStack
Jeepo,
Unless you've come up with something really cool that is eluding me (always a possibility), you cannot sync the tremolo rate to a drum machine, even with the MP-201. You can however (and this is pretty cool) send a MIDI-synced square wave LFO to the 102's freq input and have the 102 jump back and forth between two different tremolo rates with the jump points being on the beat. This assumes you are in lo freq mode. Hi mode has a different, but also cool effect.
Chris
experimentalsynth.com
Posted: Mon Mar 19, 2012 11:14 am
by ColorForm2113
ChrisStack wrote:Jeepo,
Chris
couldnt you just send that same midi synced square wave lfo to the carrier input? that should give midi synced tremolo
Posted: Tue Mar 20, 2012 10:31 am
by Vitja
Indeed! And use some CV lag/smoothing to avoid clicks...
Or use MP's LFO and sync them to MIDI clock.
MP rocks with this kind of apps!!!
Does 108 produce tremolo modulation?
Thats strange :wink:
Posted: Tue Mar 20, 2012 10:48 am
by ColorForm2113
Vitja wrote:Indeed! And use some CV lag/smoothing to avoid clicks...
I dont own a flux yet, but the square can sound tremolo-ish from samples I've heard
Posted: Tue Mar 20, 2012 2:35 pm
by 77jordan
Maybe the 108 is not meant to do tremolo. I thunk it's the coolest fooger though!
Posted: Tue Mar 20, 2012 6:10 pm
by ColorForm2113
Definitely not meant to do tremolo. Flux does more time/pitch modulation whereas tremolo is amplitude (volume) modulation
Posted: Wed Mar 21, 2012 5:21 am
by Pantherairsoft
ColorForm2113 wrote:Definitely not meant to do tremolo. Flux does more time/pitch modulation whereas tremolo is amplitude (volume) modulation
Agreed - Vibrato it does fairly well, tremolo it does poorly. 102 is king for a tremolo-style effect.
