MF-102 tremolo vs MF-108M tremolo
David Bulog
Post by David Bulog » Sat Mar 17, 2012 1:00 am
To my ears the Moog MF-102 tremolo effect is better and can handle more signal input then the MF-108M tremolo settings
Anyone prefer the 108 tremolo sound?
is there any way I can sync the MF-102 by sending it a gate input from a drum machine
thanks in advance
jeepo
Re: MF-102 tremolo vs MF-108M tremolo
Post by jeepo » Sat Mar 17, 2012 4:40 am
The easiest way to sync the mf102 to a drum machine would be to use a mp201. The cheapest way would be to output a fitting sound to an envelope follower then plug the output into the carrier. If it is a cv sequencer more options may work.
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
ChrisStack
Post by ChrisStack » Sun Mar 18, 2012 11:18 pm
Jeepo,
Unless you've come up with something really cool that is eluding me (always a possibility), you cannot sync the tremolo rate to a drum machine, even with the MP-201. You can however (and this is pretty cool) send a MIDI-synced square wave LFO to the 102's freq input and have the 102 jump back and forth between two different tremolo rates with the jump points being on the beat. This assumes you are in lo freq mode. Hi mode has a different, but also cool effect.
Chris
experimentalsynth.com
Chris Stack
I do interesting things
_________________________
www.experimentalsynth.com
www.soundcloud.com/chrisstack
ColorForm2113
Post by ColorForm2113 » Mon Mar 19, 2012 11:14 am
ChrisStack wrote:Jeepo,
Chris
couldnt you just send that same midi synced square wave lfo to the carrier input? that should give midi synced tremolo
Vitja
Post by Vitja » Tue Mar 20, 2012 10:31 am
Indeed! And use some CV lag/smoothing to avoid clicks...
Or use MP's LFO and sync them to MIDI clock.
MP rocks with this kind of apps!!!
Does 108 produce tremolo modulation?
Thats strange :wink:
Gear:Slim Phatty, Arturia Minibrute, Casio MT-600, MF-101,MF-102,MF104Z,MP-201,CP-251,Ibanez John Scofield, PRS custom 24, circuit bent Kawai R-100,Circuit Bent Roland TR-505, Boss Dr55, Akai MPK 25, Ensoniq DP/4, RME Fireface 800, tons of guitar effects.
ColorForm2113
Post by ColorForm2113 » Tue Mar 20, 2012 10:48 am
Vitja wrote:Indeed! And use some CV lag/smoothing to avoid clicks...
I dont own a flux yet, but the square can sound tremolo-ish from samples I've heard
77jordan
Post by 77jordan » Tue Mar 20, 2012 2:35 pm
Maybe the 108 is not meant to do tremolo. I thunk it's the coolest fooger though!
ColorForm2113
Post by ColorForm2113 » Tue Mar 20, 2012 6:10 pm
Definitely not meant to do tremolo. Flux does more time/pitch modulation whereas tremolo is amplitude (volume) modulation
Pantherairsoft
Post by Pantherairsoft » Wed Mar 21, 2012 5:21 am
ColorForm2113 wrote:Definitely not meant to do tremolo. Flux does more time/pitch modulation whereas tremolo is amplitude (volume) modulation
Agreed - Vibrato it does fairly well, tremolo it does poorly. 102 is king for a tremolo-style effect.
Shep on Bass - My website & blog
Bitnormal Records - Netlabel specialising in electronica
KADE - Improvised live electronica
Patient Zero - International hip-hop & electronica collaboration
