Murf Vst
n2design
Murf Vst
Post by n2design » Sat Feb 18, 2012 5:06 am
I am trying to figure out how to get the murf vst?
I installed the software and it only seemed to have included a standalone version and not a loadable vst.
thoughts?
stiiiiiiive
Re: Murf Vst
Post by stiiiiiiive » Sat Feb 18, 2012 6:51 am
From the page of the Moog website:
Availability and pricing: MuRF_Controller is a free download for all owners of the MF-105M MIDI MuRF. The VST MuRF_Controller is available for Windows and Mac. It requires a VST host and is not a "stand-alone" program.
You may have installed the standalone only...
n2design
Re: Murf Vst
Post by n2design » Sat Feb 18, 2012 2:09 pm
Found it, many thx!!
I see that the vst is missing the pattern editor and advanced options. Any idea why that is?
n2design
Re: Murf Vst
Post by n2design » Sat Feb 18, 2012 2:49 pm
Also, in the vst. The midi menu function only reflects to transmit channel. I dont see anywhere where I can select the midi output.
stiiiiiiive
Re: Murf Vst
Post by stiiiiiiive » Sun Feb 19, 2012 5:51 am
I don't DAW these days nor own a Murf; just went to look at the software on the Moog site for you. Hopefully some user will chime in...
woodington
Re: Murf Vst
Post by woodington » Tue Feb 21, 2012 5:46 pm
I'm running the VST under Cubase 6 on Windows.
I don't see access to the pattern editor (and some other bits) either.
It looks to me like the plug in is possibly a SynthEdit (or similar) based device, hence a bit rough round the edges.
It looks like it could be fun automating parameters with it though, I just hope the plug in can cope with hardcore midi wranglings.
tupinamba
Re: Murf Vst
Post by tupinamba » Sun Apr 15, 2012 10:50 pm
I cannot find a way to use MuRF VST Controller with Logic Pro as it needs AU, not VST. Any suggestions ?
Thanks.
woodington
Re: Murf Vst
Post by woodington » Mon Apr 16, 2012 1:43 pm
If your host doesn't support VST you'll need a Wrapper like the FXPansion VST/AU wrapper, either that or change hosts!
tupinamba
Re: Murf Vst
Post by tupinamba » Mon Apr 16, 2012 2:10 pm
Yes, I guess that's the downside of using the overproprietary Mac system...
woodington
Re: Murf Vst
Post by woodington » Tue Apr 17, 2012 1:40 pm
It might be worth asking Moog if they plan to update the Murf editor in the future.
I only say this as they've just recently updated the Phatty editor, which is now both VST and AU
