Hello!
I have a little problem with my Murf.
I sync it with with other gear using Cv (Moogerfoogers,voyager doepfer)
It works fine with Y cable for tap/step but when I change the pattern
I have to reconnect the jack in Murf's input to make it work .
It stops responding Cv after changing the pattern, I have tried
many different configurations ( different cv voltage, another jack,) and it
does'nt work.
On the other hand midi works fine.
Is it an issue? Should I repair it?
Help me please....
Thank You in advance
Murf cv problem
Re: Murf cv problem
?Anyone?
It supposed to be Moog forum..
Re: Murf cv problem
I haven't experienced that with my Murf, probably best to give Moog service a shout.
Re: Murf cv problem
Moog service rocks !!
It's only firmware problem....fixed
Thanks for help
Thanks for help
