Audio into Murf Step?
If I split the signal coming from my bass & put one signal as normal through my FX chain & took the other signal & put it into the tap/step on the Bass Murf & used a step adaptor, would the signal control the step (can boost it if needed)?
Ibanez SR1000e >
MF-105B >
MF-101 >
MarkBass CMD 102P >
Audience
MF-105B >
MF-101 >
MarkBass CMD 102P >
Audience
Re: Audio into Murf Step?
It should work, but you'll probably need to boost it.
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
I split the signal using the direct out from a Boss OC3 & hooking it to the step adaptor - Nowt.
I tried boosting it - Still nowt.
Clicky pedal back into adaptor it is then.
Ibanez SR1000e >
MF-105B >
MF-101 >
MarkBass CMD 102P >
Audience
MF-105B >
MF-101 >
MarkBass CMD 102P >
Audience
