I am curios has anyone tried controlling multiple expressions on a single moogerfooger at the same time with a dual expression pedal (lehle dual, Boss EV-30) or something like Multi-expression controller? Would that work and can you achieve some interesting results or benefits? Would it require a specific pedal, I assume you cannot use Y cable to split the expression signal but it has to be at least dual out (correct me if I am wrong).
Another question is it possible to cross-patch the expression I/O on moogerfooger, eg connect Envolope Out with a Mix In using a patch cable on the same Lowpass filter. Just thinking outside of the box is there another creative way to use this pedal? Thanks
Multi-expression controller one moogerfooger
Re: Multi-expression controller one moogerfooger
Haven’t used expression pedals on any of the Moogerfoogers yet, but have set up the CV out from my Subsequent37 CV to send the same signal from all 4 CV outputs. Also have utilized many different Moogerfoogers effecting one Moogerfooger. I have connected 2 or 3 (of that same signal) to one ‘fooger from Subs.37cv (I think I did it with the MF-103 and MF-107). Every Moogerfooger’s “Frequency” CV input (or whatever their equivalent is) for me is a go-to. The MF-103 is interesting when “Sweep” and “Resonance” have the same CV signal: phaser tracks frequency while resonance increases higher up (also per note tracking; MF-101 should be similar too …I don’t think the MF-101 “Sine feedback” tracks “nicely” when resonance is cranked tho). I believe you are right with the “don’t do a Y-cable” …I think we’ve both read that thread haha.
Definitely possible. I just got my MF-101, but I’ve utilized the “Envelope Out” on the MF-107 to things within that same MF-107. PLEASE PLEASE PLEASE go nuts with the “Mix” input on your Moogerfoogers …audio rate modulation of the “Mix” input seems like lite-weight ring modulation on some Moogerfoogers.
Thanks for the reply, sounds interesting I will have to do some further experiments.
On that note seems that EV-30 only 2x 10k, so I've checked for Moog products it would have to be 50k-100k to work properly. I'll have to dig around for a dual expression with 2x 50k. I have a feeling that would work then in the end if I find one for a reasonable price.
Oh found this it's very handy shows resistance for all common expression pedals.
http://expressionpedals.com/list-of-expression-pedals
