Unison In Init Patch
Polyphonic Analog Synthesizer
eltobosolo
Post by eltobosolo » Sat Nov 19, 2022 2:52 pm
Hi All,
Maybe this has always been happening and I never noticed... but when I load the init patch, it seems that there is some sort of unison mode with 4 voices going on. That is, when I press a single key, I can see 4 voices are used even though I don't have unison mode on. If I set mono mode on then only one voice is used. Is there a setting somewhere that I don't know about?
till
Re: Unison In Init Patch
Post by till » Sun Nov 20, 2022 12:24 pm
Disconnect all USB and MIDi cables and try again? Is it better? If yes, you got some MIDI loop.
Sequence:
eltobosolo
Post by eltobosolo » Sun Nov 27, 2022 6:39 pm
You nailed it - thank you!
till
Post by till » Mon Nov 28, 2022 5:45 am
If you use the original setup, set the Moog One to LOCAL OFF mode. It should work this way with DAWs
Sequence:
