Does anybody have experience with the Insert outputs?
Posted: Fri Jul 30, 2021 3:58 pm
by maddyman1000
Hi everybody
I am just trying go find out how I have to connect my insert output to the effect device t.c.electronics M-one.
Has anybody experience when using the inserts?
Thank you
regards
martin
Re: Does anybody have experience with the Insert outputs?
Posted: Sat Jul 31, 2021 4:38 pm
by maddyman1000
Hi everybodey,
I made my own experiences today and want to shre it with you to be informed:
Be sure that you you have at lest to insert adapters. To put it into the Moog Insert 1 and Insert 2
You can use an insert cable e.g. for Insert 1 and connect the "send" part of the y-cable to plug it in (in my case an t.c.electronic M-Ome effect device) the Left input.
Here you get a double mono signal on both channels in the effect device.
The out going signals have to be connected with 2 Mono 6,3mm cables to the return jacks of the both y-adapters with go into Moogs Insert 1 and 2.
Now you have to configure in the output section the synth you want to be effected by the external device to activated Insert 1 (in this case)
But be sure that it will sent out the signal to Main out L/R so there is only one output which is being connected.
Anyhow my wish a future hardware upgrade (it rather would be the Moog Two) is that you have mor than only the 2 outputs (Main L/R and Sub L/R) to get fully possibility to give every synth an idividual output.
But thats something for the future.
Thanks and regard to all
