If you created a sound when using Synth 1 is it possible inside the SAVE section to store it on location for Synth 2 ?
Or second scenery:
there are 2 good sounds in the library but the sounds allocated there are both to synth 1. Now you want to store the second sound on the synth 2 of the first. Is this possible?
perhaps anybody has an advise
thank you
regards
martin
can you force to store the sound on the synth (x) you want to use there?
moog one 16, 4x Novation Supernova 48v, Arturia Origin, BeststepPro, Analog Factory,Waldorf XT,3x Midibox Seq4+,Roland S760,Roland SPD20, 2xMotu 24AI,Access Virus TI & A,Fatar Studio2001,3x Akai APC40mk2, Novation Slmk3, LauchpadPRo,Hackintosh i5
Re: can you force to store the sound on the synth (x) you want to use there?
S O L V E D !!!
Jamie from GEOSYNTHS.com(really recommandable !!!) wrote to me :
Yes, you can move patches around within layers, you just have to make sure you are on the relevant layer. This should help.
https://moogmusicsupport.zendesk.com/hc ... -or-patch-
Jamie’s great - his soundssets for the one are very very good.
