MIDI Mapping - Some Categories have problems with the Control Parameter List
Polyphonic Analog Synthesizer
devnull
Post by devnull » Thu Dec 24, 2020 12:38 am
In Settings>MIDI Control>Edit MIDI Mapping (Synth 1 is selected)...
On the categories for:
LFO1
LFO2
LFO3
LFO4
SVF Filter
EG1
EG2
EG3
There is a '-' option at the end of the parameter lists. If you turn the soft knob to reach this "parameter", the category and parmeter fields reset to '-'. In the case of LFO1, LFO2, LFO3, LFO4, it is not possible to set the knob to the last parmater "WAVEFORM" without it jumping to the '-'. None of the categories that work have this '-' and it appears it should not be present on the categories listed here, and it certainly shouldn't cause the fields to reset.
Additionally, on the categories for:
EG1
EG2
EG3
Only two of the 11 parameters listed in the NPRN section are available.
