Transpose not independant for parts
Posted: Fri May 15, 2020 10:58 am
When working with split or layered parts, it would be VERY helpful if the keyboard transpose could be independent for each part.
This way the left side of the keyboard can be used for other than low notes (or the right other than high notes...).
With independant Transpose settings, each region could be set to whatever pitch range you want (up to two octaves above or below the key pitch).
I wonder if this is possible....
