Would anyone be willing to confirm or deny this issue with the Transpose feature?
Just plug a device transmitting on Midi Channel 1 into Midi In.
Turn OFF the Midi In Channel in the One menu.
Play a sequence on the One.
Hit the Transpose button.
Mine goes a little batty when it shouldn’t.
I’d appreciate it before or even if I have to send a report to Moog.
David
Transpose Issue Confirmation
Model D Reissue - Source - MP-201 - Theremini - Etherwave.
Re: Transpose Issue Confirmation
Could anyone please verify if this is an anomaly or not?
I’d very much appreciate it.
To add to the diagnosis, it’s been happening through all the revision updates.
Midi Control is Off as well.
Another question while I’m at it...
I’ve never been able to get any Clock Out to control anything from the One.
Don’t know if all these issues I’m having are because of Midi Implementation is still coming or it really is an issue.
Sent Moog Support my query, but have not received an answer yet.
All the best,
David
All the best,
David
I’ll have a look this pm.
I have tried it (ALTHOUGH my midi in is via the USB) however I switch midi in for synth 1 off and no issues as far as I can tell. So maybe I'm not reflecting your test accurately?
Dear Iaamusic,
Thank you for trying to cooperate my issue for me. Much appreciated.
Never checked using USB which I did tonight.
The issue still persists. Alas.
But, I did gain more info regarding it trying this.
As stated, any Midi information coming in on Midi Channel 1 only is effecting the Transpose. But now I find that Note Trigger is effected as well.
When running a simple quarter note loop from Ableton, when the One’s sequencer is stopped by releasing the Hold button, the One’s sequencer advances on the quarter notes randomly on each pass of the loop.
Almost like Midi information only pertaining to Channel 1 is somehow seeping through even though Midi is OFF and causing these weird issues.
The only workaround is now never using Midi Channel 1, but still???
Also, while I’m writing have you or anyone had any luck with the One putting out a Clock signal? Again, never had it had happen to any device I’ve tried on since I got it a year and a half ago. Everything else can clock the One, but not vice versa.
Yours,
Musically and magically,
David
Yours,
David
