Issue with INSERTS active by default
Polyphonic Analog Synthesizer
vwizz
Post by vwizz » Sun Jan 05, 2020 6:37 am
Hello,
I actually have pedals permanently connected to my inserts (typically an analog chorus on Insert 1) and I find it extremely annoying that the INIT patch as well as ALL delivered factory presets always have Inserts active for synths 1-2-3.
By default they should all be turned off.
Otherwise I get chorus on top of all Synth 1, and loud crackling with that since my pedal requires low input and -10dB correction.
—> I have to manually go and edit ALL presets one by one to de-activate the inserts one by one....
Thank you!
Iaamusic
Re: Issue with INSERTS active by default
Post by Iaamusic » Sun Jan 05, 2020 5:53 pm
Can’t you create your own init with the inserts defeated and store as a performance patch?
vwizz
Post by vwizz » Wed Jan 08, 2020 12:56 pm
Sure, but the issue here is with the presets delivered by Moog (the factory ones and the other collections).
Cheers!
