Moog One FEATURE Requests
Re: Moog One FEATURE Requests
support for Bluetooth USB dongles, to allow pairing with Bluetooth keyboards.
Since MO is Unix-based, the drivers might already be there.
Possibility to save "template " presets from which you would be able to load only parts, for example the complete fx section or the split keyboard settings
would allow to make different starting points , but not have to start from a whole older preset
would even be nice to be able to load only modulation matrix routings from templates
could be sort of " a la carte " controlled random feature
Individual voice panning!!!!! Pleaseeeee!!!!!
please let us turn off the CC7 control of the master level.
Arguably, the master level of an instrument should not be MIDI-mapped. It can be dangerous.
would love to have a boolean value toggle for gates in Mod Matrics Functions.
E.g. a new keypress toggling the boolean (1 or 0) >> mapped to VCA PAN
Would really love the option to place the inserts before the synth effects...
+20,000!!!PhilAiken wrote: ↑Fri Nov 09, 2018 1:55 pm I get why the inserts are necessarily post filter for polyphonic patches. It would be SO great to have it be available pre-filter for monophonic patches. I do not know that this is physically possible, but if it is, please consider it. My already solid love for the Voyager kicked up a few hundred percent when I started using that insert. While the One is not designed primarily to be a mono synth, since it is tri-timbral, and since there is a mono button on the front panel, it is nice to be able to maximize the range of that facet of the instrument as much as possible.
+20,000 again!
The other day trying to replicate the Juno Chorus, I founded that there is no way to select in the stereo chorus, the option to set the phase start of the LFO's. Also there is no way to select the waveform of the LFO's.
Yes I can just put slightly different rates of the LFO's to create that, but then it is not the "true" Juno Chorus. Having that options, phase start from 0º to 180º for each LFO and waveform select for the LFO's, we will be closer to that beautifull Juno Chorus. As I founded that the Juno Chorus it is just a triangle waveform in the LFO both at same rate but one at 180º phase from the other. And even if it is not 100% acurate, having those options we will have more control on the Stereo Chorus FX.
SEQUENCER FEATURE REQUESTS:
- Different sequence length per lane
- Seq Mod Only Mode like on the Subsequent 37
- Ability to note trigger the sequence with multiple voices, e.g. play a C to play the sequence in C, play a C and G to play it in both C and G
Expression Pedal Feature Request
It would be great to have the ability to map expression pedals to any mod destination at a global level. I love to be able to control the mod wheel with an expression pedal.
I know that I can map this per patch but if it was set globally I wouldn't have to edit all of the existing patches I use.
Modulate Sequencer Rate
I would love to modulate the sequencer rate when it is not synced to the master tempo. For example sending a LFO to the sequencer rate. There are many occasions where this odd idea would be really beneficial, like making unpredictable arrhythmic sequences. If there's already a way to do this, please let me know.
I suppose this would involve mapping the available sequence steps to a -1 to 1 or 0 to 1 range and allow for the sequence to go backwards? Maybe that's a mess to develop... but if it's possible I'd use it extensively!
Please allow VCA Volume to be modulated with positive voltage. A bipolar LFO modulating the VCA is always capped above 0V, even when the VCO knob is at its min value.
Some users say the restriction is there for safety reasons, but it feels unintuitive. OTOH the Master Volume knob is hardwired to CC7, which is just asking for an accident to happen. You may accidentally send a max CC7 through MIDi and blow your speakers and eardrums. I don't think modulating the VCA would be as dangerous.
Can you imagine a modular synth with a VCA which would only accept a negative CV signal, ...because it can make it too loud? Oversaturating or overdriving a VCA is an important tone-shaping technique.
Assign CONSTANT to VCA Level, and set the amount to -90 to -100%. This will allow you to use positive amounts to control the VCA level, and the FP control acts as a master volume.
Visit my synthblog...Moogs and more!
Www.synthguy.com
Www.synthguy.com
Yes, this works as a workaround, but why do we need a workaround in the first place? Why turning the VCA knob down doesn't have the same effect as applying a negative constant? If you turn the knob all the way down, you can't modulate it at all. It's not how a VCA is supposed to behave, this is not Master Volume. Limiting the output level is understandable, but restricting CV control is just awkward.
