Moog Music Forum
Share Ideas and Pass the word
Moog One SOURCE Requests
Polyphonic Analog Synthesizer
Re: Moog One SOURCE Requests
Postby MC » Fri Oct 26, 2018 12:09 am
_DemonDan_ wrote:
MC wrote:Did I write voice count? I meant voice number.
Hi MC, my bad. I missed what you were asking for.
So you're talking about a value that represents which particular voice card of the 16 (or 8 ) voice cards is firing as a modulation source?
To clarify... not to be confused with using key number as a source. Voice number is different. Think unison patch using eight voices, with the filter cutoff or glide rate modulated by voice number. Or voice number modulating the VCF EG Amount in a polyphonic patch with key assignment set to CYCLE.
Some early poly synths were not "perfect" but this can be a "feature". A good example is OBX. When using glide in unison mode, the glide circuits per voice weren't matched but this resulted in really fat mono lead sounds.
MC
Postby Deva » Fri Oct 26, 2018 2:51 am
_DemonDan_ wrote:
MC wrote:Please provide Voice Count (contiguous voices per timbre: 1-16 or 1-8) as a modulation source.
It serves as a way to vary a parameter per voice.
Good one :-)
+1
Deva
Postby Deva » Fri Oct 26, 2018 3:17 am
Some Source suggestions:
Timbre (CC74)
Breath (CC2)
Alternate (switches between two values with each note on)
Perhaps Sequencer Gate
Also, usually Random modulation sources are a single value. So if one uses Random on say 4 different targets, all 4 are having the same 'random' pattern. If it is that way in the One, then it would be nice to either have a random that is unique per parameter, or at least Random 2 and maybe Random 3...
And since there is no thread for Destination requests... I would like LFO Start Phase as a destination.
Deva
Postby PhilAiken » Fri Oct 26, 2018 9:20 am
Deva wrote:Some Source suggestions:
Timbre (CC74)
Breath (CC2)
CC74 will be important for MPE if/when it happens.
I'd take this one step further and allow any incoming Midi CC#. I know that some of the Midi functionality is being worked on still.....
PhilAiken
Postby Don Solaris » Sat Oct 27, 2018 2:52 pm
A few random number generators. i.e. RNG1, RNG2, RNG3, RNG4, RNG5. Each time you stuck a key, new set of numbers is generated. So it's not a S&H LFO, but an actual random number generator that remains fixed value for the time the voice is being played. They are polyphonic, so in reality there are "n x 16" of them with n being highest RNG(n).
Some examples:
-- each individual VCO can be programmed have a certain pitch offset for emulating manually calibrated voice board with each trimmer being slightly off. (unless there is already a random pitch per each VCO avail)
-- or to randomize other stuff. i.e. differently calibrated filter "chips" per voice, etc.
Voyager Old School serial:500
Moog Minimoog serial:3438
Don Solaris
Postby _DemonDan_ » Mon Oct 29, 2018 4:40 pm
Don Solaris wrote:A few random number generators. i.e. RNG1, RNG2, RNG3, RNG4, RNG5. Each time you stuck a key, new set of numbers is generated.
Yes, this is currently my most-desired MOD Source.
It could either be multiple Random Number Generators (like you have above) or, I'd be fine with a single RAND-VALUE as long as it delivers a unique value for each and every instance that it is read.
So... If I were to assign RAND-VALUE as the Source of a MOD, and VCA PAN as the Destination, I'd get a fresh pan for every note played (even if the notes were played at the same time).
This would also be very useful for slight variations of LFO RATEs, FILTER CUTOFF, RESONANCE, etc.
I'm currently using a SLOW LFO 4 set to S/H, with NOTE RESET On. But this is not ideal as it's a poor use of a precious LFO.
_DemonDan_
Postby psionic11 » Mon Oct 29, 2018 10:43 pm
I logged onto this forum to request this very thing. I would add that this random mod source should be distinguished from Sample and Hold or Noise as a modulation source. Those mod sources, like LFOs and ENVs, exist in the time domain. That is, they keep on acting over time instead of being a one-shot instance each time.
For example, if you use something like S&H for panning, when you sustain a chord, then you will get moving parts across the stereo field, like a warbling tremolo effect. This is desirable for some circumstances, but not all.
On the other hand, let's call this new modulation source "Spread" (as suggested by Lady Gaia on page 93 post 2765 on the Gearslutz Moog One thread). When applied to pan, "Spread" will randomly place a voice within the stereo field, say 75% left, but then that voice will stay at that position in the stereo field until the next time the voice is triggered. The next voice will be placed at 52% right, the next voice at 67% right, and so on.
At 0% spread, each new triggered modulation is 0.
At 10% spread, each new triggered modulation is between -10 to 10.
At 50% spread, each new triggered modulation is between -50 to 50. And so on.
(I think the coefficient is called a "seed" in programming terms).
As suggested a couple posts up, this Spread could also be applied to each new voice filter cutoff, giving a slight variance with each new trigger. It could also be applied to an LFO's rate, giving slight changes in rate each time a new LFO is triggered.
psionic11
Postby EvilDragon » Tue Oct 30, 2018 10:18 am
_DemonDan_ wrote:It could either be multiple Random Number Generators (like you have above) or, I'd be fine with a single RAND-VALUE as long as it delivers a unique value for each and every instance that it is read.
I think the best way would be to offer both:
Random Unipolar (0 to 1) - same value to all the destinations you route this mod source to
Random Bipolar (-1 to 1) - same value to all the destinations you route this mod source to
Unique Random Unipolar (0 to 1) - different random value to all the destinations you route this mod source to
Unique Random Bipolar (-1 to 1) - different random value to all the destinations you route this mod source to
EvilDragon
Postby MC » Tue Oct 30, 2018 11:54 am
I have used smoothed S&H (present in the Moog One) as a modulator to panning on the Voyager. It's a cool effect. Polyphonic smoothed S&H -> panning -per voice - would be a major head trip.
MC
Postby PhilAiken » Tue Oct 30, 2018 9:47 pm
MC wrote:I have used smoothed S&H (present in the Moog One) as a modulator to panning on the Voyager. It's a cool effect. Polyphonic smoothed S&H -> panning -per voice - would be a major head trip.
You can do that now. Set the S&H LFO to be per voice. (The reset on key function in the LFO more page)
PhilAiken
Postby _DemonDan_ » Thu Nov 01, 2018 11:20 am
You can also set the LFO for a single shot (REPEATS = 1) so that it stays at that random value for the duration of that note.
_DemonDan_
Postby Don Solaris » Sat Nov 03, 2018 7:14 am
You're right. One single RNG can actually handle all that since it is reset - per key. Not sure why i wanted several RNG's.
Roland have been using this type of generator hardwired to pitch for their legendary JV and JD series. It helps a lot to expand the tone, without sacrificing LFOs.
EDIT: oh now i remember why i wanted several of them. I was worried in case someone sends the same RNG to multiple destinations that consider frequency applications! i.e.: VCO1 pitch, VCO2 pitch, FM amount. So a single value would appear at all destinations at the same time, making the FM in this case kinda S&H like and sorta predictable. While with several different RNGs one could make each destination true random (per each key).
Unless they implement the RNG to be a part of the mod matrix itself in which case it can literally generate different value for each destination. Because otherwise RNG would not know on how many destinations it was being routed and hence would generate the same number for all the destinations at the same time resembling S&H type of modulation. So yeah... my vote for a few RNG's.
Don Solaris
Postby Euxine » Mon Nov 05, 2018 5:34 pm
To bend the question slightly, I'd like to see a -10 to 10v range on CV I/O, and this would be quite useful in source modulation. Having on-board scaling would mean that *some* modular settings could be internal to a patch. Rather than trying to tweak precisely to get CV interacting, you could peg settings to full on the modular, and then scale in the Moog One.
Euxine
Previous
Return to Moog One
Who is online
