3 synthy can be controlled by 3 Midi cannels ?
Polyphonic Analog Synthesizer
deboje
Post by deboje » Fri Jun 04, 2021 6:21 pm
Hi there, is it possible using the Moog One with Ableton Live10 with 3 tracks on 3 indipendent Midi channels?
I mean synth 1 refers to midi ch.1 (settings/midi i/o midi in/out channel), synth 2 to midi ch 2 and synth 3 to midi ch 3?
So that I can adress 3 different Channels to the 3 synths?
thank you for any advise and whow to do it.
regards
Sugar
Re: 3 synthy can be controlled by 3 Midi cannels ?
Post by Sugar » Sat Jun 05, 2021 4:06 pm
yes, it's all in the manual.
maddyman1000
Post by maddyman1000 » Tue Jun 08, 2021 3:20 pm
Hi
I have read all about it in the manual. But:
even when selected Per synth for in and out and given the 3 synth different midi channels (e.g. 1,2,3) the incomming data is comming in all the 3 channels, even while keybord control is off for all the 3 synth.
What is wrong here?
Thank you for any advise
Iaamusic
Post by Iaamusic » Thu Jun 10, 2021 12:59 pm
How is midi data coming in USB or DIN?
And what from?
maddyman1000
Post by maddyman1000 » Fri Jun 11, 2021 7:52 am
Midi Data come from the mac directly and I created 3 channel strip in Ableton Live 10 given each track a different Midi channel input. But when playing the moog (e.g. Synth 1 on midi channel 1) all channel strips in Live get the data as well. The same if I play on synth 2 or 3, every time all channels gets data simoultaneously.
Any idea? thanks
smv
Post by smv » Sun Jun 20, 2021 11:09 pm
I have the same issue in Live 11. Sending and receiving midi through usb.
