Subsequent37 Why? Do you Know the answer?
Everything Sub.
anAGP
Post by anAGP » Tue Aug 16, 2022 4:09 am
Hi.
So... what is going on here?
Pitch changes the waveform by more or less cycles but;
Why is it changing the shape of the waveform?
And the peak and trough ratio?
Standard, init, saw wave, nothing but playing a different note.
:shock:
Note D1 zoom
Note D1 zoom
Note D6 zoom
Note D6 zoom
Playing from highest pitch to lowest pitch
MrChumley
Re: Subsequent37 Why? Do you Know the answer?
Post by MrChumley » Tue Aug 16, 2022 9:12 am
Filter kb amount maybe?
till
Post by till » Wed Aug 17, 2022 4:26 am
Analog circuits are not 100% perfect (unless you go for high end measuring equipment). The waveshape circuits have to form the waveshape over a wide range of frequencies. And then there are phase changes in the circuits depending on the frequency. Especially the filter. And even a fully opened filter is not 100% straight on phases.
But don't worry, this is not a malfunction and may not be heard as easy as to see on a scope. It is like this on most analog synths available.
Sequence:
