Subsquent 37 Yellow keys too?
Everything Sub.
Toecutter
Post by Toecutter » Sat May 07, 2022 12:34 pm
I was all set for buying a used Sub 37, but all of them I have seen had yellow keys which totally put me off.
I am now thinking about the Subsequent 37 as I have read it used a different keyboard brand.
Can anyone with a Subsequent (who has owned one for a while) confirm the keyboard has stayed white?
I will totally not be buying one if they yellow too. My Jupiter 6 is nearly 40 years old and keys are brilliant white.
Gonga
Re: Subsquent 37 Yellow keys too?
Post by Gonga » Thu Jun 08, 2023 3:14 pm
I have two, one is a few years old, the other is fairly new. Both are very white.
My understanding is that keyboards turn yellow when they are overly protected from sunlight and/or UV, or just kept in a dark room. For example, a piano kept in a dark room, or with the keyboard cover normally closed, will yellow. I'm not sure whether or not exposure to the Sun will reverse the yellowing, but I wouldn't be surprised. In any case, if you expose your synth to a bright room with plenty of regular indirect sunshine (not direct because that's bad for electronics), I think that should prevent the issue.
MrChumley
Post by MrChumley » Thu Jun 08, 2023 3:44 pm
Are you sure? I thought it was too much UV that makes plastic keys go yellow?
penguinsanta
Post by penguinsanta » Wed Oct 11, 2023 10:16 pm
I have no idea if sunlight can undo the yellowing, but I wouldn't be surprised if it does. Still, if you put your synth in a place with lots of frequent indirect sunlight, it should last longer.
Astheologos
Post by Astheologos » Sun Oct 29, 2023 6:32 am
I heard this would help;
must be 12% Hydrogen Peroxyde
https://www.ebay.com/itm/273429049470
