Just checking what is the correct firmware version for the Sub 25????????????
Everything Sub.
Diode
Post by Diode » Fri Sep 10, 2021 12:08 pm
Hi all,
Just doing some research in prep for the Sub 25 which I am picking up next week..
Please could any fellow Sub 25 user confirm what is the correct firmware update for this instrument?
Also, my Sub Phatty does a neat thing: When I am in the 'active panel' , all adjustments can be saved as a active panel pre set, so the next time active panel is used when the Sub Phatty is powered on, the active panel settings are saved...Just wondering if this is going to be possible on the Sub 25 please????
Also, I am new to Duophonic playing, does this mode allow the user to hold a drone note with the left hand, whilst playing legato fingering with the right hand?..Also, how does LFO re- triggering mode work when the Sub 25 is in duo mode, because if one hand is droning whilst the other hand is playing a melody, then surely the LFO will get confused because the drone will stop it from re triggering?
Could anyone help?
Thanks,
Diode
