Sub25 is there a "panic" or kill all midi note command?
Everything Sub.
dan_default
Post by dan_default » Sun Feb 28, 2021 3:12 pm
I've occasionally gotten a stuck note. Usually when a DAW is interrupted mid-sequence.
Is there a panic command for the Subsequent 25?
Montfrooij
Re: Sub25 is there a "panic" or kill all midi note command?
Post by Montfrooij » Mon Mar 08, 2021 6:47 am
On the S37 it is holding both octave buttons for some seconds.
Not sure if they implemented that on the 25 as well. (can't find it in the manual)
