Holla again,
My Drum Maschine sends nots to my moog sub 25 that i dont need...
The maschine change always my presets when i push something on the drum maschine ....
How i can silients the presets or delete them ? or is there a otherway around ? i mostly go via vst to the presets and then the midi signals coming from the drum maschine to the moog.
But when i do somehting on the drummaschine the moog is changing the presets....
please help, also did the update for the moog sub 25 but still not working. I put all the same presets to the moog its a trick up the filter etc. reset again when i change something from the drum maschine :L
Stay save thanks a lot !
Subsequent 25 Midi Problem (Changing random presets)
- Montfrooij
Re: Subsequent 25 Midi Problem (Changing random presets)
Check the manual for incoming midi messages.
On the Subsequent 37 you have the option to listen to incoming midi messages and select which inputs you want (USB / DIN)
Other than that you have to revert back to the drum machine to set it to send program changes etc.
Nothing on the subsequent that I know off. (unless you add some midi box that filters messages out)
