Subsequent 25 midi question
Everything Sub.
icumdrums
Post by icumdrums » Sun May 03, 2020 5:44 am
Hello, just received my new sub 25 and have a midi question. Right now I use a Minitaur that is controlled by a Roland Spd-SX via midi, in order to trigger an acoustic drumset. I have the Roland program changes selected so that every time I want to switch presets on the Minitaur, I change kits on the Roland pad and I’m able to see everything digitally and know what preset I’m on.
My question is, now that the sub 25 has arrived, I’m hoping to use a midi selector box (so I can have both synths hooked up to the Roland) and be able to use the first 16 presets from the Minitaur via the Roland and then switch to the sub 25 for presets 17 and on.
The reasoning behind 16 presets is because I realized when using program changes with the sub 25 and the Roland, it stops at 16 because the sub 25 only stores 16 presets. So when I switch to the sub 25 (via midi selector box) on the 17th preset how can I make kit #17 on the Roland become Preset #1 on the Sub 25?
I feel this pertains to most synths in a general way, I’m just fairly new to midi and not even sure if this is possible. Thanks for reading and thanks for your time.
Montfrooij
Re: Subsequent 25 midi question
Post by Montfrooij » Fri May 22, 2020 9:06 am
You probably need to translate the midi message between the 2 instruments.
Or try if you can find an option in either the moog editor or the roland one (if there is) that can do this.
till
Post by till » Sun May 24, 2020 6:48 am
There is no hardware I can think of solving this problem.
Sequence:
Quatschmacher
Post by Quatschmacher » Sun May 24, 2020 7:12 pm
I’d suggest using something like a Morningstar MC6 to connect the three instruments. You can set up a single button to scroll PC numbers on multiple midi channels and within specified upper and lower values independently for each channel. You could probably even program it such that changing patches on the Roland determined what was sent out the the other two instruments from the MC6 if putting the Roland first in the chain.
Montfrooij
Post by Montfrooij » Mon May 25, 2020 6:55 am
till wrote: Sun May 24, 2020 6:48 am There is no hardware I can think of solving this problem.
I'm fairly new to the whole midi stuff, but I have seen LoopOp (youtube) use some interesting midi devices that can program stuff and translate messages as well.
stiiiiiiive
Post by stiiiiiiive » Wed May 27, 2020 7:05 am
I think MidiSolutions make quite customizable boxes...
Otherwise, a cheap alternative would be to have the first 16 Minitaur presets silent so that only the Subsequent 25 is playing when one of those is selected. However, that would work only of selecteing a preset after #16 on the Subsequent 25 makes it silent too.
Just thinking outloud.
stiiiiiiive
Post by stiiiiiiive » Mon Jun 01, 2020 4:21 pm
I've just discovered antoher track to investigate: the Midi Platform by Future Artist.
