Hi Guys, im using the sub37 in Ableton. Everything is fine, if i install the midi driver in win10.
But if i am reboot my pc, my automation from the sub37 in ableton is not active. if i am re install the midi driver, everything works fine. The Midi in/out is via usb
Thanks for your help
Jens
Sub 37 Midi Problems Ableton
Pharmacie rentable www.viagrasansordonnancefr.com toxicose du medicament
