Will a sub(sequent)37 send incoming midi clock via midi out?
Everything Sub.
Montfrooij
Post by Montfrooij » Sun Feb 02, 2020 4:26 pm
I have searched this forum for about an hour or so (and the www also) but can't find a good answer.
What I am thinking about is using a DAW or Drum machine as my master and sync the midi clock to a subsequent 37.
That should not be a problem when reading the manual.
But I would also like to hook up another synth to that chain and have it receive the midi clock.
(nothing else would be great, but I think I can let the synth listen only to the clock)
So in short : DAW sends midi clock to Subsequent 37 (via MIDI IN) and the subsequent 37 sends the midi clock to another synth via the MIDI OUT. (preferably without any other midi messages)
Is that possible (since the Sub(sequent)37 don't have MIDI THRU)?
Thanks in advance!
Peter
Dapifer
Re: Will a sub(sequent)37 send incoming midi clock via midi out?
Post by Dapifer » Mon Feb 03, 2020 1:39 pm
Yes, it automatically sends the incoming clock.
Montfrooij
Post by Montfrooij » Mon Feb 03, 2020 5:16 pm
Thanks a lot. And can I suppress other midi data?
(I don’t want the other synth to receive the notes that I play on the sub)
till
Post by till » Mon Feb 03, 2020 6:10 pm
MIDI clock is not per channel, but global. So all you have to do, is setting the other synths to other MIDI channels as the sub(sequent)37.
Sequence:
Montfrooij
Post by Montfrooij » Mon Feb 03, 2020 6:34 pm
Ah ok, that is another way indeed.
