I'm buying a used Subsequent 37 and want to put together a list of things to test before shelling out the money. This is my first Moog so I'm not sure what the common issues for this synth tend to be. Because it's a Subsequent I'm guessing the plastic POT from the first sub37s won't be an issue anymore. Other things I've noted so far:
- Keys and knobs function correctly (a given)
- Check to see if the unit has been opened in the past
- Test all inputs / outputs
- MIDI functionality works correctly
- Mod and Pitchwheel track correctly
- Headphone output working correctly
Are there any issues specific to the Subsequent 37 that I should look for? Thanks in advance, really looking forward into diving into this instrument.
