Sub37 Sequencer will not record new sequences
Everything Sub.
Coolian
Post by Coolian » Wed Sep 04, 2019 3:28 pm
I just got a Sub 37, but having issues with the sequencer. Whenever I try to record a new sequence, nothing happens. By this i mean nothing is displayed in the LCD and no sequence of notes is emitted from the synth.
According to the manual and videos I have researched online, I am doing everything right. But the sequencer is never activated. It is worth mentioning that the sequencer does play for presets that have a sequencer associated with them, just not when I try to record my own sequencer.
Previous measures I have taken to resolve the issue were to install both versions of firmware, which unfortunately did not solve the problem :cry: :cry: :cry:
till
Re: Sub37 Sequencer will not record new sequences
Post by till » Wed Sep 04, 2019 5:44 pm
A quick test:
Disconnect alle cables except power and audio. No USB or MIDI cables.
Powercycle the Sub37.
Does this change the behavior?
If not, check if local control is on or off. It should be on with ON without USB and MIDI connected.
Sequence:
Coolian
Post by Coolian » Thu Sep 05, 2019 2:19 am
Hi, I tried the above suggestions and the sequencer remains inactive..
DrJustice
Post by DrJustice » Thu Sep 05, 2019 2:46 pm
One thing that may be worth trying is to reset the system parameters:
GLOBAL MENU 3.3. -> INIT SETTINGS
Coolian
Post by Coolian » Thu Sep 05, 2019 4:42 pm
Hi, also tried this an nothing..
DrJustice
Post by DrJustice » Thu Sep 05, 2019 7:21 pm
OK, so not external factors and no configuration strangneness.
It's not impossible that the REC position of the PATTERN switch isn't being recognized. You could try wiggling the switch a bit in the REC position, applying a little sideways force (not too much!).
Coolian
Post by Coolian » Sat Sep 07, 2019 2:57 am
Thanks for the suggestion DrJustice. Though it seems the issue extends beyond the sequencer to the arp - no setting works on the dial but arp down.. seems like the guy who sold knew it was bunk and didn’t mention ..
Coolian
Post by Coolian » Sat Sep 07, 2019 2:58 am
Probably looking at a costly and lengthy process to get the issue sorted here in Europe
Mantrak
Post by Mantrak » Fri Nov 27, 2020 5:30 am
Exactly the same thing just happened to me. The PATTERN knob plays dead, stuck in Up position. Any news with your Sub37? Have you managed to fix it?
Bengoss
Post by Bengoss » Fri Dec 11, 2020 7:51 pm
Any fix?
Mine just stopped working.
If I use the vst editor it works, but the pattern knob doesn’t do anything.
Ben
Bengoss
Post by Bengoss » Sat Dec 12, 2020 5:13 pm
Mantrak wrote: Fri Nov 27, 2020 5:30 am Exactly the same thing just happened to me. The PATTERN knob plays dead, stuck in Up position. Any news with your Sub37? Have you managed to fix it?
Did you find a way to fix it?
Mantrak
Post by Mantrak » Sun Dec 13, 2020 5:23 am
No. I wonder whether this is a mechanical or electrical switch fault which I doubt, or a fault in the swith control circuit. At this point I am ruling out anything software related. Bummer :!:
Bengoss
Post by Bengoss » Mon Dec 14, 2020 11:57 am
Mantrak wrote: Sun Dec 13, 2020 5:23 am No. I wonder whether this is a mechanical or electrical switch fault which I doubt, or a fault in the swith control circuit. At this point I am ruling out anything software related. Bummer :!:
Thanks for your reply.
I did send a message to moog but still haven’t heard back from them.
It’s weird, it just stopped work suddenly, I haven’t moved the synth or anything.
It works with the vst editor though. That’s why I think it’s most likely a hardware issue.
Ben
Mantrak
Post by Mantrak » Tue Mar 16, 2021 9:05 am
Eventually I sent the synth to official Moog service shop, EMC in Germany. They fixed it by replacing the control board. By the way, I am highly recommending EMC, Stefan is the guy! Top quality service, as it should be for a top brand like Moog.
