Sub37 makes me a headache
Everything Sub.
xianguo1000
Post by xianguo1000 » Wed Feb 27, 2019 3:41 am
My sub37 will often get stuck in the sound during use. (The sound will always sound when it is not playing.) You must restart sub37 to be able to return to normal, but this phenomenon will occur in a while. I have not been solved until now, I am a headache.
voyager0500
Re: Sub37 makes me a headache
Post by voyager0500 » Wed Feb 27, 2019 11:17 am
Do you have MIDI running from it? Unplug everything apart from the audio cable and power cable and see it its still happening.
'i used to be a plastic cup..'
-remarkable-
xianguo1000
Post by xianguo1000 » Thu Feb 28, 2019 3:23 am
voyager0500 wrote:Do you have MIDI running from it? Unplug everything apart from the audio cable and power cable and see it its still happening.
This phenomenon only occurs when you link a computer (the logic x I use). SUB37 does not appear when running independently.
till
Post by till » Wed Mar 06, 2019 12:19 pm
I bet you create a MIDI loop. You send MIDI data from the Sub37 to the computer and the software send the data back to the Sub37. If the Sub37 is not in Local Off Mode, it will always receive every information twice: one internal and one via MIDI. Also some MIDI interfaces do have an echo function. But the later is normally switched off by default.
So check what the Sub 37 sends, what it receives and if the sub37 is set to local off.
Sequence:
xianguo1000
Post by xianguo1000 » Thu Mar 07, 2019 2:06 am
till wrote:I bet you create a MIDI loop. You send MIDI data from the Sub37 to the computer and the software send the data back to the Sub37. If the Sub37 is not in Local Off Mode, it will always receive every information twice: one internal and one via MIDI. Also some MIDI interfaces do have an echo function. But the later is normally switched off by default.
Thank you, I tried to adjust it.
uberdavis
Post by uberdavis » Thu Apr 18, 2019 4:54 am
You can stop notes playing by activating MIDI PANIC. Hold down both octave notes at the same time. You don’t need to restart.
