Hi, I couldn't get a solution to this after seaching google and these forums. Sorry if this has been adressed.
So I own a Subsequent 37 and trying to get it to work in Cubase 8.5 is nothing short of horror.
I've connected the 37 via USB(no hub) to my windows10 x64 computer.
Connected audio out on my 37 to an audio input on my Roland Quad Capture sound card.
But I can't get the Editor to work. The only way to get sound from my 37 is to create a MIDI track, setting the 37 as midi input and output, then create an audio track and enabling Monitor. I can now hear the 37 when I play, but it's not that easy with the editor.
I can control it via knobs and such, but there is no sound what so ever.
Also, after a while the buttons can't be used and there is no sound from the Moog, even if I turn it off and on again. I have to do a factory reset on the Moog to get it going again.
Can someone please help me? I'm going crazy. I just got it yesterday and I have already updated it to 1.2.0. I believe it was at 1.2.0 when I got it too, but the issue wasn't resolved after flashing the firmware.
Help.
Thank you
EDIT: Solved! It seems I didn't read the manual that well.
Subsequent 37 Editor and Cubase 8.5 [SOLVED]
Re: Subsequent 37 Editor and Cubase 8.5 [SOLVED]
I know it's been a couple months, but would you mind letting me know what the solution was for you? I've read the manual and can't figure this one out. Thanks for your help!
reaaaaalllly looking for some help on this one! much appreciated if you can.
Great bthread it is
