Multi trigger not working Sub 37.
Every now and again Multi Trigger stops working and when I turn multi trigger on it does not work.
It same for all patches as I go threw them. All patches are playing in legato not note retrigger.
The only way to resolve this is to initialise settings in the global menu.
Any advise would be appreciated.
Re: Multi trigger not working Sub 37
I've noticed the same issue. I think some other things stop working too - duo mode seems to go... weird.
Hard to pinpoint though. In my experience it's only happened with the Sub37 AU plugin loaded (but that might be coincidence). You?
Yes It does seem to be the AU version of the editor.
I have tried running the synth unplugged from the computer and it behaves as it should.
I will try it with the VST version and see if that makes any difference.
