Hi Folks
I'm lucky enough to have a Sub Phatty and a Minitaur/
I've currently got the Minitaur hooked up to the Sub Phatty as an external instrument.
But I'd like to create some Duophonic sounds
Also, can I poly-chain them?
Help and any other cool tricks would be appreciated.
Gordon
Sub Phatty and Minitaur together
Re: Sub Phatty and Minitaur together
If you set the Sub to high note priority and the Minitaur to low note priority you get duo sound, there is no need to poly chain
http://audiotecna.info
How should I connect them together to achieve this please?bichuelo wrote:If you set the Sub to high note priority and the Minitaur to low note priority you get duo sound, there is no need to poly chain
Well, there is no correct or incorrect way to chain them. If you use each one on one channel of your mixer/soundcard you will get a duophony, and if you feed one of them to the second one's external audio input you will get something like the paraphony the Subsequent doesAnimalbeats wrote:How should I connect them together to achieve this please?bichuelo wrote:If you set the Sub to high note priority and the Minitaur to low note priority you get duo sound, there is no need to poly chain
I would set the Minitaur to Low Note (on the Editor you find it at Under the Hood tab, or a globat one at Settings) and the Sub Phatty to High Note (on this one it can't be set per preset). You can set this on the latter under Prefs at the right column
