SS 37 CV Osc 1 wave pot problem
Everything Sub.
umami
Post by umami » Sun Sep 17, 2017 6:35 pm
The wave selection pot on Osc 1 doesn't respond until it hits nearly the 5th mark on the dial, but also fails to adjust the square wave pulse width as much as Osc 2. Anyone else having this issue?
SlowLFOtoPitch
Re: SS 37 CV Osc 1 wave pot problem
Post by SlowLFOtoPitch » Mon Sep 18, 2017 1:14 pm
Hi umami,
It sounds like you may need to run a pot calibration. This is a fairly simple process that only requires you to send sysex files to the instrument.
Instructions and pot calibration files can be found here: https://www.dropbox.com/s/ai4ko7cg0tns9 ... L.zip?dl=0
TAYLOR MOTT
SERVICE DEPARTMENT MANAGER
MOOG MUSIC INC.
P: (828) 251.0090 ext. (217)
Fax: (828) 254.6233
umami
Post by umami » Mon Sep 18, 2017 5:44 pm
Done and done--seems to have improved the situation. Thanks.
