sub 37 CV editor
sub 37 CV editor
does the sub37 editor and driver work with the new subsequnt 37 cv? if so where do i get it? thanks
- Rufus the Dog
Re: sub 37 CV editor
Pretty sure it does. If you register your Sub 37 CV with Moog you get a link to the editor
R.
R.
It does, got it working here but i got a problem that the editor isnt syncing the presets to the moog correctly. I always have to click "caputre hardware".
I just tried troubleshooting. Maybe its only a problem with my system here, i can imagine everything works fine for the most users.
- Rufus the Dog
There was some advice elsewhere here about removing the Sub 37 folder and restarting the Editor. I did that and it seems to make sure I could capture all my Sub 37 CV presets even though I think I have to click on Capture Hardware to display them - prior to that it would go through the download procedure but not display the presets or even realise they have been dowloaded.
There is also advice about saving any presets that you have stored on your computer for later as, obviously, removing the Sub37 folder also removes any stored presets.
R.
R.
thanks...will try it tonight and see if i get the same problem
got it workimg but it does not seem to ync correctly. The edit will show one preset while the display on the sub 37 is showing another preset name. what am i missing?
did an export of the factory presets in the librarian and that seemed to sync it back up
