Sub Phatty update?
Everything Sub.
misfitit
Sub Phatty update?
Post by misfitit » Thu Oct 20, 2016 12:10 pm
I'm curious to know if I'm missing something. The latest update I see for firmware and Editor is still may back in 2013. Is this actual? or have I missed a posted link for a more recent download?
seems kind of crazy if so.
paramnesia
Re: Sub Phatty update?
Post by paramnesia » Thu Oct 20, 2016 1:36 pm
the public beta was posted in the beta test forum, email [email protected] if you need or want access
http://forum.moogmusic.com/viewtopic.php?f=20&t=25934
[SPH] Sub Phatty release candidate firmware 2.1.12 available
Postby GilW » Wed Aug 03, 2016 12:19 pm
Hello moog beta group!
Sub Phatty release-candidate firmware v2.1.12 is ready for testing. This version fixes LFO Rate changes when tweaking EXT IN.
Installation instruction remains the same. Please update your SPH, use it massively and report any issues as new threads on the forum.
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
misfitit
Post by misfitit » Thu Oct 20, 2016 7:40 pm
thanks, I don't have access so I guess I'll have to wait till it's final. Any word on a working editor?
breun
Post by breun » Fri Oct 21, 2016 3:51 pm
The Sub Phatty editor was released quite a while ago. Isn't it working for you?
misfitit
Post by misfitit » Sat Oct 22, 2016 12:05 pm
no usb midi. not reliable, anyway. I heard this was getting updated a while back but have never seen anything.
breun
Post by breun » Sat Oct 22, 2016 12:12 pm
Hm, works fine for me, always has. If you have a specific problem, I'd contact Moog support and tell them about it and supply details about your setup, versions of OS, firmware, editor, etc. You could also try starting a new thread on this forum about it. Or have you already found other posts detailing the same problem you're having?
You could also request access to the beta testers forum and give the latest beta release a try.
Rick B
Post by Rick B » Sat Oct 22, 2016 2:45 pm
Does anybody know if there will be useful functionality or improvements added to the Sub Phatty in this update. One wish, poly chaining to Voyager...
Voyager Electric Blue, Sub Phatty, Moog Prodigy
misfitit
Post by misfitit » Mon Oct 24, 2016 10:14 am
breun wrote:Hm, works fine for me, always has. If you have a specific problem, I'd contact Moog support and tell them about it and supply details about your setup, versions of OS, firmware, editor, etc. You could also try starting a new thread on this forum about it. Or have you already found other posts detailing the same problem you're having?
yes, there are a number of posts about limited or failing USB midi connections between Sub P and editor in DAW and stand alone. The problem seems to not exist with standard 5 pin midi connection. Moog has stated that the problem would be addressed but it seems it's been the case since original release.
medwaystudios
Post by medwaystudios » Sun Oct 30, 2016 5:46 am
The editor now supports multi client IO so you can feed both the Sub and the DAW from its USB midi. This makes it a lot easier to setup as you don't need to connect the physical midi IO anymore.
Windows 7 x64 / Sub Phatty
j_peAk
Post by j_peAk » Mon Oct 31, 2016 11:10 am
Sweet
Any idea of a public release to this update?
Cubase 9.0.20
Cubase 8.5
Win10 Pro 64bit
i7 3.4Ghz 4770 Haswell
16GB
Samsung 840 Pro SSD, Western Digital Black
Nvidia GTX 960
Moog Sub Phatty, Crowminius, Jasper, Korg MS-20, Korg DW8000, Yamaha TX7
Nektar P4 Midi Controller
willissom1
Post by willissom1 » Mon Nov 07, 2016 3:18 am
medwaystudios wrote:The editor now supports multi client IO so you can feed both the Sub and the DAW from its USB midi. This makes it a lot easier to setup as you don't need to connect the physical midi IO anymore.
Good information
Denim
Post by Denim » Wed Dec 14, 2016 7:35 am
Anyone got any idea about when to expect a new release of the new editor/firmware for the Sub Phatty?
Two years have passed since I sent my bugreport..
breun
Post by breun » Wed Dec 14, 2016 9:08 am
Top priority in the beta forum seems to be getting the update for the Minitaur out, after that I guess they'll continue work on the Sub updates.
What version of the Sub Phatty firmware and editor are you currently using? If you're using Windows: what driver? (On Macs you don't need to install any Moog specific drivers, but it seems this is required on Windows.)
Denim
Post by Denim » Wed Dec 14, 2016 10:06 am
breun wrote:Top priority in the beta forum seems to be getting the update for the Minitaur out, after that I guess they'll continue work on the Sub updates.
Using the latest official drivers/firmare and editor for Windows, don't remember exactly now as i'm on a different computer, but I know I have the latest. After weeks/months of trial-and-error testing and dialoge with one of the Moog-developers, I had to give up and go over to only using DIN-midi. Then everything works. But since I do a lot of automation in my productions, using the Phatty editor directly in my DAW would be a big time saver, now I have to do everything via CC-midi.
Emiliano Cerruti
Post by Emiliano Cerruti » Thu Feb 16, 2017 8:42 pm
I'm not authorized to view the post of the beta firmware update.
Somebody can help me on what I need to do please.
Thx.
