- While holding one or more keys down, the panel buttons and knobs become unresponsive, sometimes taking several seconds between changing a control and the effect of it being heard, then a further delay before the LEDs reflect the new setting (for buttons). The programmer section is still responsive though.
- The unresponsiveness extends to the keyboard handler, as in keys responding sluggishly to pressing and releasing (the arp plays for a little while after I let go of all keys).
- The Arpeggiator tempo is erratic, changing tempo by itself or as panel controls are manipulated. It also adds one silent note to the pattern, unless back/forth is on.
- If I record something in the sequencer, the panel can become responsive again, but not always (very hard to diagnose). However, the max arp tempo then becomes very low (EDIT: low arp tempo is due to the arp clock divider being at higher value than anticipated).
- After testing for a while, the synth becomes even stranger, with the arpeggiator ceasing to work, not responding at all to buttons presses, regardless of which patches I recall. This requires a power cycling of the synth to undo.
- Selecting the patch, switching off sync and saving it in a new preset slot with arp sync switched off does not help - I wonder if it behaves even stranger after that.
The behaviour is indicative of the CPU being completely bogged down somehow (interrupts firing constantly, FIFOs filling up uncontrollably - that kind of thing).
The synth runs the latest firmware v 1.2.0. The patch was created from the standard init patch. I've not been able to reproduce the behaviour yet, by making new patches and saving them with arp sync on - only this one patch and its descendants exhibit this behaviour. There is another thread here with an issue that could be related: Arp Rate Knob Working Properly?
Could some of you guys try this patch (attached below) and see what happens?
