Sub 37 - Modulate between slopes in beat
Hey guys, there's something I've seen done often that I just can't figure out. How to module the filter slopes to change in beat. To change from 6,12,18,24,6,12,18,24, etc in beat. I connect the mod dest to the slopes and am able to make the sporadically change but nothing that's stable. Can anyone point me in the right direction?
Re: Sub 37 - Modulate between slopes in beat
Select filter slope for one of the mod destinations and sync that LFO to arp/midi. Adjust the LFO speed to get one step per beat. Play around with the mod amount knob and the "start' position of the slope. (I think) if the knob is turned 'up', the slope has to be at the lowest position (so the lfo can modulate it 'up') and visa versa. You'll probably want the lfo shape to be on triangle to get a smooth back and forth sweep thru all the steps.
awesome! Thx so much - will try out tonight.
