sub 37 plug in works, but filter is having tracking issues
Everything Sub.
yogaflamemusic
Post by yogaflamemusic » Sun Jul 31, 2016 8:48 pm
while doing in manually it makes a weird flutter sound, when you use the mouse and modulate the filter in the plug in its nice and smooth,, but when you manually sweep the filter it makes a fluttering weird sound choppy.. how to fix this? Thanks, im using ableton, sound and evyerything else works perfect. Amazing product !! :D
breun
Re: sub 37 plug in works, but filter is having tracking issu
Post by breun » Mon Aug 01, 2016 1:14 am
Do you disable local control in the Sub 37 menu when connecting to a DAW?
yogaflamemusic
Post by yogaflamemusic » Wed Aug 03, 2016 12:44 pm
ill check that out and get back to you soon
yogaflamemusic
Post by yogaflamemusic » Wed Aug 03, 2016 1:05 pm
I tried turning off the panel in local control, but then it turns off all movement using filter.. so that didnt work.. the filter is smooth in the editor software, but when you manually turn filter while pushing key its all choppy and sound cuts and makes weird sounds... This could have started after the 1.1 update , maybe warm up time? :?:
paramnesia
Post by paramnesia » Wed Aug 03, 2016 1:41 pm
yogaflamemusic wrote:the filter is smooth in the editor software, but when you manually turn filter while pushing key its all choppy and sound cuts and makes weird sounds...
do you have a plastic or metal filter pot shaft underneath the knob? if plastic, you might contact Moog Service for the upgrade to the revised metal filter pot shaft - requires the right hand panel board swap, which if you are handy with tools, can perform at home without having to send the synth into a service center
https://www.moogmusic.com/support/service
moog music wrote:If you need to contact our Service Department please reach out to [email protected] (828) 251-0090 ext.246 or [email protected] (828) 251-0090 ext.246.
Sub37TE V1.2 / 4 X CP-251, 3 x MF-104M, MF-102, MF-107, MF-108M, 4 x Mother32 + 5 x 104HP Eurorack, Windows 7 - 64 Bit | Ableton Live 9.5 + MaxMSP https://www.modulargrid.net/e/racks/view/458782
