Sub 37 sequencer cheat sheet
Posted: Sat May 14, 2016 6:02 am
Here's a "cheat sheet" to make the operation of the sequencer easier.
Edit: an updated version is attached below
Share Ideas and Pass the word
https://forum.moogmusic.com/
The modulation stuff was basically copied from the manual, apart from finding the differences between the main list and the one in the SEQUENCER >> MOD DST menu However I just tested now, and it's indeed centred around MIDI note 60.mikeh11 wrote:I know you put a lot of effort into making this, and I think it's really good. I have some comments, though:
In the MOD SRC table, for the KB Track entry: doesn't middle C have MIDI note 60? I know there's disagreement on whether it is called C4 or C3, but I didn't think it changed what the MIDI note number was.
It was called ARP RUN in Firmware 1.1, and was updated to ARP ON with firmware 1.2, so let's go with that.Some notes on the Mod Dst table:
- ARP RUN is called ARP ON in the Editor and Hardware.
Indeed. It's in the manual but not in the synth... Too bad that, as you say having VCA level as destination would be nice.- I don't find OUT VOL in any destination list in the Editor (MOD Dest or Seq Mod Dest), nor on the hardware itself. However, there is a hardwired mod dst for VCA Level.
Good point. However, I think this list should reflect the menus, not the hardwired sources/destinations since that would pull in several more entries that would need the difference explained, so I'll leave as it is for now. (I do wish that they would be selectable in the menus as well though, and that you could press MOD DEST button and grab the knobs in addition to cycling them with the MOD DST button, but it's not really important - I understand the rationale for doing it the way it is)- You say "F.CUTOFF: Filter Cutoff Freq (only for seq mod!)" Technically, that's true - only SeqMod - but both Mods have dedicated mod amounts for the filter cutoff. I flip/flop on this issue myself... should the hardwired connections be included in a list of "everything you can do", or should they be left out because they're not in the list of selected parameters? I can't decide.
To make it consistent with the menus-only listing, I think I'll leave that out in this document.Would you want to list the standard LFO waveshapes along with the programmable sources, just for completeness?
Not at all. On the contrary, thank you for the corrections, I'm all for quality in documentation (and everywhere else!)I hope this doesn't come across as harsh or too critical. I certainly don't mean it that way.
